How to get my Ground Control down?
  • limp mode
    • Jun 2012
    • 117
    I have koni with GC and it's just not low enough... I will be happy if I got it down about another half of an inch up front I have the shortened struts and they are spun all the way down.
    What is the best way to go about this? Shorter springs?? I don't want to loose the performance aspec of it but it does need to come down some more. Help
  • IronFreak
    • Dec 2012
    • 3702
    Not sure about your wheel selection but you could probably drop the sleeve down the strut tube some more, that would allow the spring to ride lower(wheels and tires could interfere because of inside clearance issues). It would require cutting and welding. How much were your strut tubes shortened?
    Instagram @rebellionforge
    • limp mode
      • Jun 2012
      • 117
      I think it was shortened 3-4 inches.. I don't want to cut these up I rather just get some bc's or something... Do you think springs would do it???
      • Lof8
        • Oct 2006
        • 2827
        try shorter springs
        S50'd
        Originally posted by TDE30
        What is this faggy shit I have happened upon?
        I can always live in a M3. Can't M3 a house.
        • noE30
          • Jun 2008
          • 2260
          3-4"???
          I thought most of the time gc only did like 1-2".
          Flickr
          @michael.colby on Instagram
          "All he needed was a wheel in his hand and four on the road"
          • IronFreak
            • Dec 2012
            • 3702
            How do you know they were shortened, id question your certainty on that if you think it was shortened that much. What kind of shocks are you running. I dont think you can cut a strut tube thatuch and still fit an insert in. Plus your camber would be crazy.
            • Cinnabar325is
              • 1064
              No way they're shortened that much. Mine are shortened 1" and I still have 6 threads to go in the front and the car is pretty low IMO.
              If they were shortened 2" and I bottom the adjustment out, I bet the car would be pretty much undriveable.
              '89 BMW 325is Zinnoberrot / '88 VW Jetta GLI 16v Tornado Red / '89 VW Jetta GLI 16v Tornado Red / '89 VW GTI 16v Bright Blue Metallic / '91 BMW 325i Black / '91 BMW 325i Sport Black / '92 VW GTI 16v Black / '92 VW GTI 16v Montana Green / '01 Audi A4 Avant TQM Silver Metallic / '01 VW Jetta GLX VR6 Black
              • smerfs
                • 319
                from what I understand, If you actually cut your struts 3-4" then you wouldn't be complaining about ride height as your oil pan should be flush with the pavement.
                The sway bar tab looks exactly like the ones on my modified struts done by GC, so I would assume you only have yours cut 1" if it was done by them. Mark told me that in order to shorten the struts more than 1" after they have been modified, you have to grind off the sway bar tab, cut an extra inch off, and put everything back together with the sway bar tab moved down an extra 1"
                a little more info on your kit like what shocks and springs you have would be helpful in providing you with a better answer. A shot of the cars ride height with wheels on would work too
                320I - under construction
                • lambo
                  Captain Scene Points
                  • 10953
                  I think ak- has GC's with incredibly short housings, maybe he'll pop in.
                  • limp mode
                    • Jun 2012
                    • 117
                    Hahaha they were only shortened 1" sorry for the confusion... I called GC and went with shorter springs and higher spring rates... They had a 5 inch spring instead of my 6 inch that is on the car. We will see how this turns out.
                    • yeaseth
                      • Jul 2011
                      • 302
                      cool cool, I was going to say dang! 3-4 inches? haha Im getting some new stiffer front springs as well. What rates did they give you?
                      benvideoproductions.com
                      http://www.youtube.com/watch?v=617yNrOrRfo&
                      • lambo
                        • 10953
                        Interested to see results. I just pm'd Mark with some questions regarding the same sorta deal.
