ground control spring rates
  • kamotors
    • Nov 2007
    • 7102
    I'm thinking of switching out my H&R race springs and going with a ground control setup.
    My question is what spring rates would you recommend for a turbo E30 auto-x setup? My current H&R race setup feels too soft and the rear squats too much.
    7speedshop.com
  • IronFreak
    • Dec 2012
    • 3702
    Call Mark at GC, the dude is super cool. has helped me with a lot!
    Instagram @rebellionforge
    • acolella76
      • 2950
      Seriously, why do people post this question anymore when it gets asked every other day? You're a cool dude, but you've been here for a while. You need to learn to search. My advice to you is either A) search old threads and see what people run (I run 500/~550) or B) call ground control and see what they recommend.
      -Alex
      • Robert
        • Dec 2010
        • 3770
        500f/750r
        • Earendil
          • 1662
          My understanding is that suspension is a highly dynamic thing, consisting of many elements. Not only is the existence of ones exact setup not guaranteed, but assuming it does it's near impossible to find using the search function. What r3v needs is a chart made up of the most common elements that get combined, and post it in a sticky, such as:
          Use (autox, track, rally, street, mom-as-passenger)
          Shock
          Spring rate
          Bar size
          Weight
          Power
          Desire to under/over-steer.
          That would go a long way to answering those looking for a more typical setup, while also helping those that are looking at something close, but not quite what's on the chart. In the mean time, I don't mind people asking, and I don't mind reading the answers :)
          If you are positive that GC is the brand you want and offers a solution, then by all means call the GC experts and tell them what your setup is!
          1989 - E30 - M20B25 - Manual. Approx 300,000+ miles - Track Rat & Weekend Fun
          2000 - E46 - M52TUB28 - Manual. Approx 130,000 miles - [not so] Daily Driver
          I'm looking for a Lachssilber Passenger Fender and Hood. PM if you have one or both to sell!
          • mulletman
            • May 2012
            • 801
            Off topic: I will be in Reno tomorrow night. You should give me a ride in that ridiculously powerful car of yours.
            • acolella76
              • 2950
              Shock
              Spring rate
              Bar size
              Weight
              Power
              Maybe I am the only one who thinks spring rate advice threads get posted all too often. And for what it's worth, there is already a suspension setup thread and it is stickied at the top of the page. Or perhaps I should just start one of my own?
              OP, if I were you, this is what I'd do:
              450-550 front springs
              Convert the rear to coilover and double up on springs. Put a low rate tender spring (about 150-200lbs) and a higher rate spring on top to equal the total spring rate you want (so if you put a 300lb spring on top of a 200lb spring you would effectively have a 500lb rear spring). This acts similarly to progressive rate springs and is helpful in high horsepower car that have trouble putting power down. But I'm just going to guess that you probably don't want to switch to rear CO so you would probably be better off running a spring that is more on the softer side. IMO I would probably look in the 500-600 ballpark.
              Of course, sway bars are used for fine tuning to the drivers preference, but disconnecting your rear sway bar will also help put the power to the ground.
              -Alex
              • Hellabad
                • 807
                Actually, this is not correct. It is very hard to imagine how "stacked springs" work, unless you have spent a lot of time designing electrical circuits. (truth!)
                Here is how I would try to explain it:
                Imagine two pillows stacked on top of each other. Two pillows are softer than one pillow.
                Imagine that one is a feather pillow, and one is a foam pillow. When they are stacked together, they will feel softer than just one pillow.
                Through a bunch of mathemagic, the formula ends up like this:
                (feather pillow times foam pillow)
                divided by
                (feather pillow plus foam pillow)
                equals
                super soft pillow.
                for resistors we have:
                (300 ohms times 200 ohms)
                divided by
                (300 ohms plus 200 ohms)
                equals
                120 ohms
                for stacked springs we have:
                (300 pounds/inch times 200 pounds/inch)
                divided by
                (300 pounds/inch plus 200 pounds/inch)
                equals 120 pounds per inch
                This is really really hard to wrap your head around, so try to imagine the pillow scenario.
                If you are very mathematical, then check this link:
                Adding a resistance in parallel to another resistance will reduce the equivalent resistance. Parallel Equation: R1 = 10Ω R2 = 20Ω Req = R1R2/(R1+R2) = (1/R1+1/R2)-1 Req = 10•20/(10+20) = 6.67Ω
                here is a link for electrical resistance:
                Parallel Resistor Calculator R1 + R2 = R equivalent resistance circuit equivalent total resistor finder made easy piggyback = parallel - Eberhard Sengpiel sengpielaudio
                Here is a link for actual car springs:
                Advanced Control Engineering Manufacturers of Sway-A-Way off road performance shocks, Pfadt Race Engineering suspension products for road and track, and aFe Control suspension products.
                Ask here if you have more questions. I can't promise I can answer right away, but I can help you understand how these things squish.
                Jay (Ground Control)
                PS. Just to really make things interesting: The same formula is used for volume of flow through two different sized pieces of tubing.
                Here is my photo gallery answering common questions about Ground Control Suspension, and e30 suspension problems in general.
                Ground Control Gallery
                The Ground Control facebook page: Dragged, kicking and screaming into social media to see what happens next.
                • DRTSRFR
                  • May 2008
                  • 1836
                  Pillowfight!!
                  Thank God for the pillow analogies...
                  Jay has been my suspension mentor for over 20 years. I'd still be an idiot if it weren't for the mental pictures.;)
                  Suspension tips here...
                  http://www.r3vlimited.com/board/album.php?albumid=757
                  • kamotors
                    • Nov 2007
                    • 7102
                    I was just hoping for an auto-x specific spring rate, I know its asked a lot, most other threads were for DD rates and not higher HP cars.
                    car doesn't run currently, replacing head with a cammed head.
                    7speedshop.com
                    • lambo
                      Captain Scene Points
                      • 10953
                      ^^^ That is weird to think about, that the spring rate goes down with a helper spring...is that due to the reaction forces from the springs acting on each other, or something?
                      • acolella76
                        • 2950
                        Damn Jay, you just showed me up big time. My boss who used to be a crew chief for IMSA and WC cars said he would just 'stack springs' on cars that were having power down issues, so I assumed it was as simple as stacking and adding. I didn't think there was a mathematical formula for that, so thanks for posting that!
                        -Alex
                        • Earendil
                          • 1662
                          It's because... pillow...
                          If you apply 200 lb to a 200lbs spring, you will have compressed the spring 1 inch, right?
                          If you then place that compressed spring and weight onto another 200lbs spring guess what, the new bottom spring now has 200lbs* on top of it, so it will ALSO drop an inch.
                          The spring between the bottom one and the top weight still has 200lbs sitting on top of it, and it has no reason to do anything but stay where it is. The end result is that you put 200lbs and dropped 2 inches, which you would say is a 100lbs spring.
                          Does that make sense for those that like math a tiny bit more than pillows, but are confused by adding and multiplying? :)
                          Now, what I suspect would help is if you had one spring embedded inside the other (think M20 valve springs for those that know). In this way, both springs could actually push independently of each other. But I doubt this would give any sort of progressive effect.
                          *Yes, I know it's actually 200lbs + weight of the spring. I didn't want to complicate things.
                          • mulletman
                            • May 2012
                            • 801
                            Dammit....
                            • JeffRR
                              • 277
                              He was bumping the roll stiffness distribution foward (increasing understeer), assuming he was talking about "stacking" springs at the rear.
