Gc coil overs vs koni & hr race
  • Kevinl
    • Oct 2012
    • 897
    Other than hight adjustment what are the benefits of ground control coil overs over Koni adjustables & H&R race springs
    I want this thing to tear up the corners but rather not drop the coin on coilovers
    1989 BMW 325is Lachsilber metallic 5 speed
    2007 BMW 335i KARMESINROT 6 Speed manual
    2011 BMW X5 35I
  • Holland
    • Nov 2008
    • 7212
    Adjustable ride height, more car specific spring rates, and a linear rate spring versus the H&R progressive rate.
    Honestly if you are going to invest that kind of money in Koni and H&R, just spend the few extra dollars on a proper GC setup and not do the same job twice.\
    I run H&R on my car. Great setup but I want coilovers. Means I have to do the job twice.
    Originally posted by DEV0 E30
    • Kevinl
      • Oct 2012
      • 897
      Damn I think I might of saw your car today
      The price isn't really close they are almost double the price
      2011 BMW X5 35I
      • Holland
        • Nov 2008
        • 7212
        In Prescott? It's on weaves right now.
        Springs and shocks alone they aren't far off. It's when camber plates and mounts come into play. Rear mounts are a necessity when upgrading and fronts are recommended. Camber plates are also a good idea but not necessary.
        • Kevinl
          • Oct 2012
          • 897
          Yeah I was up there for work. unless there are other dimantswartz with big driving lights around up there
          What do you mean mounts?
          The camber plates replace the strut mounts correct what mounts are in the rear
          2011 BMW X5 35I
          • AE86
            • 272
            IMHO linear springs > progressive springs... H&R's and I.E. are progressive and coilovers are typically linear
            WTB: Diamond Schwartz Hood
            • Holland
              • Nov 2008
              • 7212
              Rear shock mounts. You are going to need to beef them up for anything other than stock shocks. I know some people use E46 convertible (I think) rubber mounts, or I used the GC mounts which are reinforced. I HIGHLY recommend doing rear shock mounts as most people neglect doing them and they eventually tear.
              • limp mode
                • Jun 2012
                • 117
                i have gc and its amazing
                • acolella76
                  • 2950
                  It's worth buying Ground Controls the first time around, I know I wish I had. There's a good chance that you are going to replace the H&R race for coils anyway.
                  -Alex
