Has anyone installed OEM E36 M3 springs in to their E30?
    • 37833
    I know that they will physically fit, sure.
    I am piecing together a beater E30 and it currently has cut springs and sits way too low. I've got a set of E36 M3 springs laying around and was thinking of throwing them on! Just curious if anyone has tried this? A "stock" look is totally fine with me but I'd like to avoid going full "monster truck" too.
    Info and insight appreciated.
    Grover Beach, California
    BimmerHeads.com
    It should not be hard to locate a set of "take off" springs that you could get for free, or nearly so.
      • 37833
      That's hardly the issue. I've got a set or two of E30 springs laying around.
      Was more curious if anyone had tried the E36 M3 springs.
      BimmerHeads.com
      • drulle
        • Dec 2008
        • 1906
        Interested as well... have a set of 1998 e36 m3 (sedan) stock springs laying around.
        Particularly in rear setup. I would love to have slightly lowered/ firmer rear end ride height.
        M3 springs are definitely stiffer, about 1.5" shorter, and coils are 2-3mm thicker.
        "i love vee tek, its a wonderful sound when you driving right by it"
        If you bought anything from me, please leave a feedback here: http://www.r3vlimited.com/board/show...ghlight=drulle
        • serdar255
          • Feb 2013
          • 395
          Any of you guys try it?
          image (10) by serdar.gurhan, on Flickr
          PM me for custom shift knobs and stickers!
          Originally posted by marshallnoise
          You ain't done working on a car unless you are bleeding.
          • dr.gonzo
            • Nov 2009
            • 206
            Aren't oem springs progressive in rate? i see a lot of benefit if these did fit.
            www.roadreview.net
            • MattAvino
              • Jan 2011
              • 2147
              If this works out it'll be a great oem+ super cheap mod
              Sent from my SCH-I545 using Tapatalk
              E30 buildy things
              http://www.r3vlimited.com/board/showthread.php?t=195286
              • JCarp90
                • Feb 2011
                • 1759
                I don't understand how this has not been investigated before.
                • AndrewBird
                  The Mad Scientist
                  • 11898
                  Well, just judging from car to car, they should be stiffer, but could make an e30 sit higher. The fact they are shorter then e30 springs though should help with that. Someone try it and post pictures.
                  • trcooperone
                    • Dec 2008
                    • 90
                    Someone give me some springs and Ill put them in tonight!
                    • ELVA164
                      • 4861
                      I would be curious how they compare to E30 M3 springs, which I have installed and like quite a bit.
                      • matthugie
                        • Mar 2004
                        • 1810
                        I'm amazed I never tried this, I had sets of both these and e36 PSS9 springs but never tried the stock e36 m3 springs. I should have, the PSS9 springs were way too low and rode on bump stops.
                        88 325is - S52 powered
                        Originally posted by King Arthur
                        We'll not risk another frontal assault, that rabbit's dynamite!
                        • e30fish
                          • Oct 2009
                          • 332
                          I have a pair as well from my old e36. I'm currently on e30 m3 rears with both pads in. I'm putting in unknownish sportlines in. I might try both and see.
                          • Wanganstyle
                            • 2828
                            I rode in a '90 e30 325is with stock m20/g260 and E36 M3 springs installed with bilstein e30 dampers.
                            It was lower, rode nice. thought it was stock for a moment and then it looked to low.
                            0 details of install; was my friends car.
                            • e30fish
                              • Oct 2009
                              • 332
                              Anyone have a chance to try it out?
