Rubber liners that go on springs..
  • kkamakasi
    • Sep 2009
    • 202
    So I did not like the fact that the ride for my car so rough with lowering springs and the fact that the rear camber could not be adjusted..
    So I got a set of stock OEM springs and replaced them into my car.
    Now I noticed that the front springs only had the rubber liner things on the top side of the springs and did not have them for the bottom side.
    So when I put in the OEM springs into the car, I never bothered to put the rubber liners on both the top and bottom side of the springs.
    Now, the car is making rattling noises from both sides of the car when the car is moving and also when I jump on the front part of the car.
    Is this rattling because I did not put in the rubber liners on the bottom side of the springs?
    It should not be, The springs should be under pressure all the time when the car is resting on the wheels. Sounds like you have other problems.
    • kkamakasi
      • Sep 2009
      • 202
      NVM found the problem..
      The strut was not completely screwed into the strut housing on the passengerside.
      Used an oil filter wrench to screw the strut all the way into the strut housing and voila! no more noise!
