does anyone know where to get 2.25id coilover sleeves with adjusters??? i believe gc's and ge's are 2.5id.
coilover sleeves and adjusters
Tags: None
for the front our rear of your car? If its for the rear Ireland engineering has them.
They come with top hats as well just not pictured.sigpic
Instagram @rebellionforgeComment
ill call to double check. everyone told me that they were 2.5. thanks
im mostly interested in the fronts. but thanks, ill keep that in mind.Comment
.........You're not going to get that small of a spring on your front strut tube.........you need a minimum of a 51mm sleeve (2" roughly) which leaves a 1/4" split between both sides. after the thickness of your sleeve and the shelf wall of your adjuster it won't fit. The only one I know of that's smaller is M struts and I can't remember what the diameter is (something like 47mm) but it still wouldn't work.sigpic
thanks for the help. i didnt realize that. you cleared things up for me..........You're not going to get that small of a spring on your front strut tube.........you need a minimum of a 51mm sleeve (2" roughly) which leaves a 1/4" split between both sides. after the thickness of your sleeve and the shelf wall of your adjuster it won't fit. The only one I know of that's smaller is M struts and I can't remember what the diameter is (something like 47mm) but it still wouldn't work.Comment
