Additional drop sans Drop Hats?
  • bimmer2288
    • Feb 2006
    • 273
    I'm installing Bilstein Sports and HR Sports on my 325i. I have read about the drop hats and don't want to mess with the issues that so many people have had with them.
    What about spring pads? I know thinner pads are made, would these be a viable solution to get another 5-10mm of drop without compromising safety or the components?
    Any pictures with guys running on thin or removed spring pads?
  • mulletman
    • May 2012
    • 801
    Plenty of people remove the spring pads entirely. Seems to work fine.
    • Deltron89
      • Nov 2012
      • 333
      Ripped mine out last week when installing my camber plates. Haven't noticed anything compromising at all. The amount of drop achieved is not really noticeable. I say do drop hats and take out the pads. There are threads about drop hats and how to do them correctly so you don't get binds or grinds.
      • SkiFree
        • Jun 2011
        • 2766
        If anybody that is having issues with drophats, it's not as much an issue with the hats and much as the issue is the installer.
        ADAMS Autosport
          • 37832
          You can run no spring pads without issue.
          Another option for an additional drop would be GC Touring camber plates. They give an additional 12mm since they have a shorter stack height. (I am using them). But of course this isn't exactly a cheap option.
          There's always the option to cut 1/2 coil from the spring too. It sounds scary but it's not.
          Classic BMW Specialists
          Grover Beach, CA
          www.BimmerHeads.com
          • bimmer2288
            • Feb 2006
            • 273
            You are for real on the spring cutting?
            I may get it all put together and see how it all looks before taking any measures to alter things too drastically.
            • campbellj25
              • 181
              I'm running vogtland springs, e90 drop hats and no spring pads in the front. Kept the pads in the rear just to give it some positive rake. I've had no issues without the front spring pads, but they are so thin I don't think it would make a noticeable height difference with them in or out.
                • 37832
                Did it to mine.
                Grover Beach, CA
                www.BimmerHeads.com
