chasing a rear end clunk when shifting/ letting out the clutch...poly rear bushings..good shape/almost new...trans mts. stock but in good shape and bolted tightly...driveshaft brgs seem tight and ok....rear diff mount seems ok...rear sub frame isn't cracked...engine has BMP solid/poly mounts they are tight...cv joints are tight...that seems to leave either the diff/ring gear needing to be reshimmed, or the rear strut mounts. they are stock rubber type and i have bilstein sports w/ h&r springs and h&r rear swaybar. the strut brgs don't seem to be cracked (the rubber); do they just get streched out or what? what are the advantages of the solid type of strut brg, other than less compliance?
thanks,
greg
thanks,
greg
R.I.P 07/01/09 - 04/23/10 :(
