i thought my stock rear shocks were bad causing a clunk, turns out they were fine and that wasn't the prob. so i was wondering is it worth it to install the solid type rear shock mounts if your stock ones are ok. what is to be gained... i already have bilstein sports, h&r springs, h&r rear swaybar, and poly rear a-arm mounts. it wound seem that the next weakest links would be the subframe mounts or the shock mounts. will it make a difference or should i wait until they wear out and replace them with the solid type then?
greg
greg
