1985 318i
  • T.O.
    • Nov 2012
    • 6
    1985 318i
    Just got a 1985 318i. Looking to lower it right away. The problem is I heard the front housings on this model are 45mm? Don't know if this is true or not. Because of this can't find any coilover sets that easily or a good shock and spring combo. Also will the raceland coilovers fit this car??
  • T.O.
    • Nov 2012
    • 6
    Also would the e30 ground control kit work?
      • 37829
      You'll need to upgrade to the 51mm housings to run anything decent (including Ground Control).
      Please don't buy that Raceland junk!
      Classic BMW Specialists
      Grover Beach, CA
      www.BimmerHeads.com
      • T.O.
        • Nov 2012
        • 6
        Thanks for the help! How do I upgrade to the 51mm housings??
        • Smelser
          • Feb 2011
          • 633
          if its an 85, it may be 51mm housing already, I thought it was the earlier 84 that was 45mm
          sigpic1984 318i Total conversion to a DIRT race car.
          Check out our build on facebook @ www.facebook.com/brewstermotorsports
          • T.O.
            • Nov 2012
            • 6
            I should measure to double check. My buddy has a 1989 325i parts car. If mine are 45mm, could I get everything I need for the swap from his car?? What all exactly do I need.
            • Holland
              • Nov 2008
              • 7178
              Nope. 85 and earlier are 45mm. Essentially non ABS cars.
              Op, you can make a decent setup with 45mm housings, although 51mm is the more common application. Bilstein sports are available in 45mm.
              Originally posted by DEV0 E30
                • 37829
                Everything swaps right over. (Except the strut insert of course)
                You could also benefit from his front brake setup though since it's designed to use the vented rotors and yours is not.
                Grover Beach, CA
                www.BimmerHeads.com
