Springs and shock absorbers. Which combination is the best?
  • limas
    • Jan 2011
    • 44
    Hi,
    my car is a BMW E30 318i, model 1984, 4-door.
    I am looking for buying a kit of springs and shock absorbers. I am also thinking buying a cheap coilover, if the quality is good.
    The car will be used only for rides as a second car. But i want to achieve a better appearance and a more tight driving feeling.
    Can you advice me?
    Greetings from Greece!
    Cheap and quality are mutually exclusive. And there is no "best" spring/shock combination. The choices come down to how the car will be used and how much money can be spent.
    • deutschman
      • May 2008
      • 5958
      Your from Greece? You guys still have money to blow on your cars?
      • limas
        • Jan 2011
        • 44
        I beg your pardon?
        • limas
          • Jan 2011
          • 44
          As i wrote above, the car will be used as a second car, some days per week. I intend to spend max 300 euros.
          • mr ilia
            • May 2011
            • 582
            You need to buy oem replacement shocks and you will be ok.
            • limas
              • Jan 2011
              • 44
              Thank you. And what about springs?
              My E30 now rides on Bilstein absorbers, but i do not know the model. If i remove them from the car, could i read on them the model?
              Every absorber can be fitted in every spring?
              I do not know much for absorbers/springs..
              Also, could you suggest me a tested combination ?
              • mr ilia
                • May 2011
                • 582
                in my reference I meant shocks as struts/absorbers/incerts...or anything that represents a shock.
                As for the springs, just go oem or some stock e30 m3 springs..those will be ok with stock shocks/absorbers/struts/incerts.
                • limas
                  • Jan 2011
                  • 44
                  Thank you.
