i recently finished swapping in a z3 rack in to my 85 325e, getting some strange steering feel. when not moving the weight is pretty much even across the entire length of the rack, but when i start moving thar is a bit of a stiff spot in the center and it gets rilly quite light close to full lock. eny idies on what is going on?
front suspension set up
204/40/17 tiers
17x8 25off set with 25mm spacers(to clear brakes rx7/corrodo)
off set control arm bushings (about 9 deg caster)
h&r lowering springs (about 2deg camber)
poly steering bushing
thanks in advance
204/40/17 tiers
thanks in advance
