Problem installing my front h&r race with billy sports.
  • Aviator
    • 616
    Looks like my stock drop hats or what ever ya call them aren't going to work... There's an inch or so of slop now with the Lowe springs. Do you have to use different drop hats with these springs?
    84 325e Burgundrot S52 M Tech 1.
    http://www.r3vlimited.com/board/showthread.php?t=250109
  • golde30
    • 11464
    no, when you put the car on the ground, the gap will dissapear.
    IG: @Baye30
    • Aviator
      • 616
      Ok yeah with the housing clamped on the work bench with the spring and hat on top there's an inch or more of a gap. It would make sense that the weight will bring the spring up to the drop hat. It just seems that a good sized bump would losing the spring up and it would pop out this way...
      • ak-
        • 12422
        R3vlimited, the spec-e30 racing community, and myself promise you that it will not pop out from a bump. :)
        1991 325iS turbo
        • Aviator
          • 616
          [ATTACH]72202[/ATTACH]
          • mr ilia
            • May 2011
            • 582
            That's normal.
            • Aviator
              • 616
              Ok thanks guys. Love trailer park boys btw!
              • fronton
                • Oct 2009
                • 1262
                don't forget spring pads.
                • Aviator
                  • 616
                  Got the spring pads...
                  • Aviator
                    • 616
                    Not too happy with my control arms... I've had the car for four years and haven't looked at them till now. I can reuse them, but should I replace them since I'm doing struts and springs?
                    • acolella76
                      • 2950
                      If you don't replace the entire control arms, replace the ball joints at least. They can be pressed out of the arms and new ones can be bought for ~$20 each.
                      -Alex
                      • Aviator
                        • 616
                        Where do I get them at?
                        • einstein57
                          • Jun 2007
                          • 10780
                          Just think of all the people only running 4 and 5" springs with the same struts.
                          www.gecoils.com
                            • 37829
                            Spring pads are not required FYI. They have been off of my current E30 since 2005.
                            You can buy all 4 Moog ball joints (great brand) for about $60 from RM European.
                            Classic BMW Specialists
                            Grover Beach, CA
                            www.BimmerHeads.com
