I'm having a hard time installing the front sway bar brackets on! To slide it into the slot and then align it on for the bolt,i can not make it happen try it for 2 hrs and no luck.Any insight or tip are helpful
					Front sway bar bushing PITA to install
 I use 2 tools -large channel locks and a small vice grip.
 1) Wiggle the bracket into the slot as much as you can
 2) Use the large channel locks to squeeze the bolt hole side of the bracket up against the atachment point on the frame
 3) Use the small vice grip at the bracket edge (so you don't cover up the bolt hole) to hold it to the frame
 4) Insert bolt
 Others use a bottle jack or other type of jack to push the bracket up against the frame
 Thanks; will try this procedureI use 2 tools -large channel locks and a small vice grip.
 4) Insert bolt
 Others use a bottle jack or other type of jack to push the bracket up against the frameComment
 The procedure mention above works best!Comment
 I used a bench vise to press mine in... Took about 2 mins and wham bam... Just make sure they line up in the right spot before pressing. Its a bitch to have to pull the sway bar and inch it over a 1/4"Comment
