Lowered car, looks like *ss
  • MrK
    • Jan 2006
    • 709
    I just put in sport lowering springs (don't know the brand, they were bought second hand, the brand name had evidently worn off). They're red, and they lowered my touring about 1.75" front and back. They seem progressive, since they're still kinda comfy when I drive normally, and stiffen up drastically as they are compressed.
    BUT, the original reason I put them is to lower the front of the car a little more than the back, but now the back is in-line with the front (character lines are now parallel to the ground. In my opinion, that looks like *ss. I wanted the back to still be a little higher than the front for that aggressive stance. Would putting my stock springs back into the rear cause death/destruction on the highway or is it worth a try? Or maybe I should get thicker rubber pads for the rear (if any exist).
    Suggestions?
    This is your M20 on steroids:
  • mk-ultra
    • Apr 2004
    • 22
    there's bigger pads or you can run 2 at a time...stock springs would be way too soft.
    and you'll get too much understeer with soft springs in back....the e30 are already prone to understeer so i wouldn't want to make things worst :D
    • trashcop 80s 80s
      • Jun 2004
      • 1130
      Take the pads out of the front and add some to the rear.
      • Old'n'Slow
        • 436
        I had to use a 10mm pad on top of a 5mm pad in the rear to make my late '80's car look right. I now how about the same fender gap f & r and the car is nicely raked...
        • madjurgen
          • May 2005
          • 1203
          I used two 10mm.
          As time went on, the factory developed the car each year, making it faster, more comfortable, and capable of handling at higher speeds.
          You don’t want this. You want the trickiest, most dangerous, oldest model you can find. Only then can you prove to the world that you’re a man.
