Steering Rack Question
  • ky0u
    • Dec 2012
    • 808
    Hi R3v
    I have an e46 m3 steering rack I would like to put in my car. I need to know what tie rods I need to use in order to make this work
    Web Designer / Front End Developer
    My Portfolio & Website
    IG: @w_illriderz
  • ky0u
    • Dec 2012
    • 808
    Bump!
    IG: @w_illriderz
    • ky0u
      • Dec 2012
      • 808
      Bump! Anyone know?
      IG: @w_illriderz
      • ky0u
        • Dec 2012
        • 808
        bump
        IG: @w_illriderz
        • pantelones
          • May 2011
          • 533
          Does the e46 rack have tie-rod on it? And do you have a spare e30 tie-rod, or would you be willing to take out one (just the ball joint) of your tie-rods to compare? If the ends are the same, and within adjustment then you can use the e46. If they are not, then you have to check either the inner tie-rod thread that connects to the rack, or the compatibility of the outer tie-rod that threads into the inner tie-rod. The e30 and e36 are different male and female ends, so you may have to use e30 or e36 outer rods. Both will fit the e30. Use your thinking cap buddy! ;)
          A man chooses, a slave obeys... Would you kindly?
          • Wanganstyle
            • 2828
            Originally posted by ky0u
            Hi R3v
            you need e36 outer tie rods; all e36's use the same.
            I fitted new e36m outer tie rods to the Z4 rack that was installed in the race e30.
            I installed a e46m3 rack into my e36m3 grocery getter - used e36M outer tie rods with it.
            z3 = e36/7 and same as e36 all
            z4 = e46 and same as e46 all - bigger diameter taper ball joint connection to the hub.
