I've seen the "master list". It does not specifically list the e and es models. I'm curious what the spring rates of the OEM springs are on these two models. Might as well throw in vert springs while we're at it. I've done a lot of searching with little results for e and es springs.
I just picked up an '84 eta. I have access to vert springs and es springs, so which is stiffer? Are they the same height? (I realize ride height is affected by car weight)
I'm looking to replace the cut springs on the car with either the vert springs or the es springs. I'm looking for the springs that will provide the lower/stiffer ride of the two. I have a barely used set of Billy Tourings to put on there as well.
