Z3 steering rack question
  • Hoffbrohaus
    • Sep 2013
    • 519
    I found a Z3 rack locally for $125 it's off a 2000 2.8L Z3. I read in some threads that all Z3 racks are the same.
    What concern's me is this:
    Originally posted by Wh33lhop
    According to RealOEM, all Z3 non-M racks are identical (http://www.realoem.com/bmw/partxref.do?part=32131095575). However, it has been reported first-hand that more than one 1.9 rack has been tried out to have been 3.2 turns lock-to-lock, so try before you buy as RealOEM is not perfect.
    How do I "try before I buy" from a junkyard? can I turn it with a wrench or something and count the turns?
    '90 325is
  • Todd Black 88
    • Oct 2007
    • 3449
    Yes
    Originally posted by codyep3
    I hope to Christ you have looks going for you, because you sure as fuck don't have any intelligence.
    2001 silver/Blk 325 cabby. SOLD
    2002 325xit Sil/blk. SOLD
    2010 F650gs twin
    • Hoffbrohaus
      • Sep 2013
      • 519
      Originally posted by Todd Black 88
      Yes
      Ok any more details? Like should I use a set of vice grips? do you know the specific mm wrench? should I use a socket? Just want to bring everything I need to the yard so I only make 1 trip.
      Thanks
      '90 325is
      • davesmystery
        • Jun 2013
        • 106
        Vice grips work fine, you'll be turning the spline up top so just be careful not to mess up any of the grooves.
        1992 325ic, Alpine over Indigo.
        • e304me
          • Feb 2006
          • 1374
          Don't use vice grips you will fuck up the splines. Just turn it by hand. Bring a sharpie to mark it so you can count the turns. Also beware fluid might squirt out.
          • Hoffbrohaus
            • Sep 2013
            • 519
            Thanks, I found a place in Phoenix that has rebuilt racks in stock for $200 plus a core of $150. http://www.dicksdriveshaftphoenix.com/ I will probably just do that. Just deciding if $350's worth it since they won't take my E30 rack as a core. The junkyard one from a 2000 Z3 is $125.
            '90 325is
            • e304me
              • Feb 2006
              • 1374
              rebuilt is not the same as re-manufactured. Rebuilt usually just means they replaced the seals
              • Hoffbrohaus
                • Sep 2013
                • 519
                Thanks, so do you think I should get the junkyard one for $125 and do my own seals? I read the maval rebuilt units are not always the best.
                '90 325is
                • MoparJ
                  • May 2007
                  • 258
                  I bought mine at work through LKQ. When I received it, I put an old steering wheel directly on the rack to test the ratio. I can't remember if it was an e30 or e36 wheel, but it slipped right on the rack splines.
                  Jason
