So it's leaking. What now?
  • Zreberlcoe
    • 1555
    so I saw this after pulling into the driveway. I jack it up and the drivers side boot on the steering rack is wet so I squeeze it and fluid gushes out. What's the bad news!? Is the good news I have to do a e36 m3 or z3 rack swap?
    1991 325i Calypso Coupe
    Like Grandfather, Like Father, Like Son
    BMW
  • Zreberlcoe
    • 1555
    No one?
    BMW
    • EyExR
      • Jan 2011
      • 959
      Be happy about the 'good news' part...
      My 325iX DIY Threads:
      Front Wheel Bearing Replacement
      325iX Rear Subframe Bushings and MUCH more w/pics!
      325iX Steering Rack Replacement, Suspension, & Oil Pan job w/pics!
        The rack seals are gone and the rack needs to be replaced with a reman unit. You can swap to a different rack if you want.
        • Zreberlcoe
          • 1555
          Quotes on racks?
          BMW
          • davesmystery
            • Jun 2013
            • 106
            Then just google the rack you want, or ebay. Reman racks will go for around $200-300 for e36 and z3. Or find a used one at your own risk for cheaper.
            Also, if you have an airbag car you might have to modify the firewall where the steering shaft enters the cabin.
            1992 325ic, Alpine over Indigo.
            • ///digitalme
              • Dec 2009
              • 2088
              Or delete your power steering and call it a day
              • Zreberlcoe
                • 1555
                That's an option... But I have been led to understand that doing rack swaps is a huge improvement to your e30!
                BMW
                • Zreberlcoe
                  • 1555
                  Originally posted by davesmystery
                  http://www.r3vlimited.com/board/showthread.php?t=66247
                  Yee I have an airbag car.
                  BMW
                  • Hoffbrohaus
                    • Sep 2013
                    • 519
                    Anyone know about these Ebay guys?
                    This one is only a $40 charge but not sure if it was an OEM that was reman'd or not
                    Detroit Axle
                    This one has a $150 core charge but it says they are OEM reman'd.
                    Car Steering Wholsesale
                    One more OEM reman'd for under $200 but with a $150 core.
                    BuyAutoParts
                    I'm waiting to hear back from Rich at http://rackdoctor.net/ too. I will post what he says.
                    '90 325is
                    • Hoffbrohaus
                      • Sep 2013
                      • 519
                      From Rich @ Rack Doctor
                      "Thank you for your interest. I’m sorry but I do not swap cores. I am also a BMW enthusiast. My racks are OEM and exactly what you order is what you get with matching tags. I am very aggressive about having the correct unit for my customers. Finding the Z3 cores has lately proven to be a task (for real OEM z3 racks) there are many systems that will claim they are all the same but they are definitely different. Recently I have paid upward of $250.00 just to have the proper cores in house. This is why I can’t swap cores."
                      He's right, every place I call thinks all Z3 racks are the same. I will test the turning ratio of the racks at this place in Phoenix to see what they truly are. If none are 2.7 lock to lock I'll give Rich a call.
                      '90 325is
