Swaybar Endlink Installation EXTRAVAGANZA
  • SkiFree
    • Jun 2011
    • 2766
    - Andrew Adams @ Ireland Engineering
    NOTE 1: (just to get this out of the way). The angle doesn't matter (this applies to those shortening their endlinks to get the bars parallel to the ground) except for clearance reasons. An angled sway bar still has the same torsional characteristics throughout the range of motion as one parallel with the ground would because the moment arm is equal and opposite on each side. That is assuming that the endlinks have no load in the neutral position which is what adjustable ones solve. If anything, by shortening the overall length of the endlink you are reducing the arc radius of the endlink which can cause your swaybar to bind (and destroy the heim-joints).
    SWAY BAR ENDLINK INSTALLATION:
    -Mount the bar using the chassis pivot bushings to start with (the center bushings) (be sure to liberally lube both the inside and outside of the bushing using the provided grease). This will leave the bar ends hanging.
    ***(for adjustable endlinks only)
    - Put the car on jackstands.
    - Unscrew the top endlink heim-joint from the rest of the link, put it through the sway bar (do not tighten, it will be dangling).
    - Put the bottom piece of the endlink in its spot but do not tighten.
    - As you jack the rear suspension up you will see that the upper and lower portions of the endlinks will line up. With the suspension compressed, reattach the endlink portions and tighten
    ***(for stock-style endlinks)
    - Put the car on jackstands (unless you’re using ramps)
    - install one end of the endlink through the swaybar, do not tighten.
    - With a jack start to compress the suspension, the other end link will naturally start to line up with the hole on the car. Slide stud through; begin to thread the nut on.
    - After making sure the suspension is fully under load you can tighten the endlink nuts down.
    - DO NOT install the endlinks while pre-loading the suspension (by man-handling the endlink into place). If you install the endlinks with the car in the air it will pre-stress the swaybar when it's on the ground at neutral, this will lead to premature endlink failure.
    For a car whose endlinks include a U-shaped bracket (E30) make sure that you leave the U-bracket loose when setting the endlinks. Place a floor jack under the control arm, and cycle the suspension up and down. The U-bracket will "automagically" position itself in the best orientation as the suspension is cycled, and then it can be tightened down. During the bar's rotation it will have a slight angle to its rotation, If you don't do allow the bracket to be slightly angled; the endlink heim-joint will want to rotate beyond its limits popping out the seals (this is a major reason behind premature endlink failures).
    ADAMS Autosport
  • pantelones
    • May 2011
    • 533
    Originally posted by SkiFree
    Your version of "right" and my version of "right" must be different.
    To be honest, now I am just totally confused...
    I referenced this thread which made sense in terms of force being applied, and movement.
    In neither one of my set ups was there ANY pre-load on the bar which was my original intention for buying the adjustable links. After you telling me that they were installed wrong, and reading that thread I "fixed" them and they are still wrong? I did not extensively cycle the links using a jack, but I did snug them (allowing movement to settle) and move the steering both lock to lock and bounce the front of the car to see if any binding was occurring, and there was none. My brackets are slightly angled and the links are in the best position possible to be within the limits of the heim-joint.
    Acourding to SkiFree BOTH of these set ups are wrong...
    My original... (Upper joint is a bit crooked...)
    link by Los Pantelones!, on Flickr
    And my shortened...
    IMG_4772 by Los Pantelones!, on Flickr
    Basically, clarify what is exactly meant by this step...
    - As you jack the rear suspension up you will see that the upper and lower portions of the endlinks will line up. With the suspension compressed, reattach the endlink portions and tighten.
    Is this referring to making the link parallel with the vertical axis or is this to due with the tension, or lack of tension on the link? I really can't put that together in my head as to why you would do this... Honestly, I'm just looking for clarification. Not trying to start an argument or prove you wrong.
    A man chooses, a slave obeys... Would you kindly?
    • bastianshaw
      • Jan 2007
      • 2210
      so the moral of the story here is to cinch the mounting nuts while the car is under its full weight or w the suspension fully compressed?
