0.16 degrees front toe on both sides (says total toe 0.31 degrees) good toe for new suspension completely stock ride........Looking for stability not twitchy.
0.16 degree front toe both sides...Good?
toe in? yeah, that should be fine. I run 1 degree of toe out on each and it's twitchy. You need some toe in otherwise the car can wander to some extent. If you're trying to remove all tire wear from toe just set it to 0 everywhere but know that you should probably "drive" the car 100% of the time.'84 318i M10B18 147- Safari Beige
