Issue with my suspension in the back
  • timmyr77
    • Jun 2012
    • 353
    So recently my left rear axle went out. So I replaced with a used one that is pretty good condition. But after it being replaced, when I accelerate quickly to the left or right there is some kind of clunk from the left wheel. It never happens if I am going straight. I thought it could be my tires rubbing on the inside of my wheel well but I'm not sure. Could it be some kind of tensioner ? I am pretty sure I installed everything correctly on the axle so I hope it's not that.
  • timmyr77
    • Jun 2012
    • 353
    Ya so I would appreciate any help. Anyone experienced this? I just want to know what too look for first. My dad said it was probably something with the suspension or some tensioners. Wanted to get some other advice too tho. Thank you
    • AndrewBird
      The Mad Scientist
      • 11898
      Is it a single clunk, or more of a repetitive rattle? How do your rear upper shock mounts look?
      • Holland
        • Nov 2008
        • 7212
        Did you get the proper axle? ABS ring isn't interfering is it? Wheel bearing binding?
        Originally posted by DEV0 E30
        • timmyr77
          • Jun 2012
          • 353
          its more of a rattle. the shock mounts seemed fine when i was installing the shocks, but i could check. and i pulled the axle from an 87 vert with abs just like mine
