Power Steering Tension
  • bats
    • Jan 2008
    • 128
    My adjuster bar's teeth were all grinded away (#6 in above). Perhaps I was doing it wrong, but to loosen or tighten the P/S belt, do I simply turn #9/#10? Or do I have to loosen/remove all the other related bolts like #7?
    Or does someone have a way to pry the pump to add tension? Couldn't think of a way of doing so.
  • bats
    • Jan 2008
    • 128
    Anyone anyone? Bueller?
    Sent from my Nexus 5 using Tapatalk
    • AndrewBird
      The Mad Scientist
      • 11898
      You need to loosen #7 and #10 and also loosen the bolt on the bottom of the pump so it can pivot. Then turn #9.
      • bats
        • Jan 2008
        • 128
        Thanks! Made sense once I figured out which one was the pivot bolt.
