I've researched quite a bit and cant decide wether to run either: A- "No rear sway" B-"factory rear sway with poly bushings and new links" OR C-"aftermarket bar"
Certianly the cheapest option would be to ditch the rear bar altogether. However, the car is sitting or a bilstien BTS kit (slightly stiffer springs than H&R sport) and I dont know if the springs will be able to control body roll enough on their own. But I also dont want a huge rear bar that induces snap oversteer and causes the rear end to loose grip early.
I would like the car to be as forgiving and grippy as possible WITHOUT sacrificing performance with a retarded ammount of understeer.
Im only 18 and just getting into autocross. I really want to learn car control before anything else.
Suspension as it sits now (if this helps)
-ST adjustable front bar
-Condor UHMV M3 offset fcab's
-front x brace
-front and rear strut braces
-poly RTAB's
-aluminum subframe bushings
- Cosmos camber plates
- Bilstien BTS kit
-Z3 2.7 turn rack
-All new ball joints and tie rods
-front x brace
-poly RTAB's
- Bilstien BTS kit
-Z3 2.7 turn rack
