Cheap aftermarket rear sway endlink option w/o sphericals
  • nrubenstein
    • 3148
    As usual, I forgot to take pictures. Of course.
    Anyway, the solution to the clunking rear sway endlinks that I came up with is pretty simple: Take a front endlink, cut it in half, thread it, and rejoin the two pieces in the correct (90 degrees turned so that they are parallel) orientation.
    Some additional fiddling may be required to get them to fit, but this was what worked for me. Hopefully it lasts, as it's nice having a rear sway again. I have literally had these stupid things sitting in my parts box for the last 9 months waiting to get around to playing with them.
    2002 BMW M3 Alpinweiß/Black
    1999 323i GTS2 Alpinweiß
    1995 M3 Dakargelb/Black
    - S50B32/S6S420G/3.91
    1990 325is Brilliantrot/Tan
    1989 M3 Alpinweiß/Black
  • Earendil
    • 1662
    So you thread both halves into a male configuration, and combine them again with a threaded female sleeve? Interesting! I suppose the more concrete way would be to weld it back, maybe adding a brace. But not all of us (myself included) have that skill and equipment just lying around :)
    1989 - E30 - M20B25 - Manual. Approx 300,000+ miles - Track Rat & Weekend Fun
    2000 - E46 - M52TUB28 - Manual. Approx 130,000 miles - [not so] Daily Driver
    I'm looking for a Lachssilber Passenger Fender and Hood. PM if you have one or both to sell!
    • Roysneon
      • 4505
      I'm sure that heat would do absolutely nothing good for the bushing, though.
      So what is the advantage to this? The adjustable length?
      Originally posted by mbonanni
      I am a pursit now.
      • nrubenstein
        • 3148
        The issue is that the stock endlinks have the balljoint perpendicular to the lower bushing. You need to rotate them so that they are parallel to match the motion of the trailing arms.
        • nrubenstein
          • 3148
          Honestly, this is not a good case for welding.
          • AndrewBird
            The Mad Scientist
            • 11898
            What size die did you use to thread them?
            • berlow94
              • Jan 2013
              • 1063
              Your never supposed to weld something that is under tension really...
              The best one-stop shopping for German car parts and lifestyle: http://www.gutenparts.com/
              • vpilarrt
                • Jun 2006
                • 2096
                Why does your title say "w/o sphericals"? Are you not using the ends with the bearings and joining 2 of the other ends together? Pics would really help. And are you trying to sell the set you've "had sitting in your parts box for the last 9 months"?
                • Roysneon
                  • 4505
                  He means not these
                  Or something like this
                  They don't hold up too well to being exposed to the elements and will wear and fail quite quickly on a street driven car.
                  I am a pursit now.
                  • nrubenstein
                    • 3148
                    I used 3/8ths. Very convenient to source a joining nut from home despot.
                    • nrubenstein
                      • 3148
                      Why on earth do you think that I'm trying to sell anything?
