450/650ish
Coilovers
E36m3 coils for 5-lug swap
4-lug with a generic setup
I have some others of a GC setup I did for a 4-lug setup somewhere in the Suspension subsection as well.
GC is amazing quality, I prefer Koni over billy, but it all depends what you're actually going to do with the car.sigpic
Instagram @rebellionforgeComment
I dont get this whole spring height thing.... How would i know what height i need to have my car lowered the way i want... Can u help me with that? Or if i just get the gc adjustable coils would that do the job? How much would it lower the car?Comment
the collar moves up and down the thread sleeve adjusting height. you need to talk to GC directly, they'll set you up with the proper spring length, most 2.5" springs come in 4,5,6,8,10" lengths.
your best bet is to stop looking for interwebz quick answers because everyone is bias as hell and call Mark at GC. tell him EXACTLY what you have now, and what you want to accomplish. they'll set you straight.sigpic
IronFreak is right. I am very new to E30s and have never seen such primitive front suspension designs before but I called GC and in a quick 5-minute phone call he explained everything I needed to know when the time came to make a decision.
Ironfreak eventually I may be PM-ing you about some fabrication of my own struts since I already have koni yellows but need to bump my spring rates in the front and back.Comment
Based on your ride height pic assuming you're on stock length strut housings which I'm 90% sure you are (Bilstein sports don't come shorter, only iX HD's do), I'd got 5" springs front and rear with 440/650 rates. If you already have the dampers you want to use, GC springs and adjusters are only $400 a set brand new. If you only buy springs, you'll still need adjusters. IDK if GC springs will work with JOM adjusters, but I do know that GC adjusters are FAR superior in quality and adjustability. And you probably don't even have adjusters in the rear with JOM's, you can't do that on GC's.The first car I ever rode in was an e30
1992 Mauritiusblau Vert
2011 Alpinweiss 335is coupe
2002 540i/6 Black/Black
2003 GSX-R 750 (RIP)Comment
Easiest way to determine what springs you need is measure the ones you have now. If you go to GC and keep the perch in the same place relative to the spindle and run the same springs, you will be at the same height (or close) to where you were before.Comment
