I swapped out my steering rack with a rebuilt stock one from rackdoc. I thought it was the exact same rack and steering angle but noticed that after the swap, the angle increased. Does alignment cause changes in steering angles?
increased steering angle after rack swap?
Your signature picture has been removed since it contained the Photobucket "upgrade your account" image.Tags: None -
If you have a difference in toe of course it will change final steering angle. I don't know the specifics between the racks, but you should get an alignment unless you want to buy tires too.'84 318i M10B18 147- Safari Beige
