Tiered replacement in NJ
  • 96belmont
    • Dec 2010
    • 23
    Need tie rods replaced for my e30....any shops in nj that are any good?
    Also what should is the approximate cost for this?
  • FLG
    • Sep 2011
    • 3165
    Guten parts, give Levent a call. Honestly theres gonna be a lot of "while your in there" stuff you should do as well if it needs attention.
    -Sway bar links/bushings
    -Control arm bushings
    -Check for wear/loose control arm ball joints or ripped dust boots and if found replace entire control arm
    -Build http://www.r3vlimited.com/board/showthread.php?t=295277
    • 96belmont
      • Dec 2010
      • 23
      Thanks.
