to start, I've got an 88 325is on CX racing coils. I recently started having an issue where it feels like my car is bouncing up and down at lower speeds and it pulls to the right pretty hard. once I get around 55, it shakes like a bastard, still pulling. I just had it aligned today and I'm still having the issue. my front camber is at -3.0° both sides and the toe is within .01° on each side. the caster was a little out of whack (around 6.8°), but it obviously can't be adjusted without plates and they were even regardless. I also had the wheels balanced just in the off chance it would cause that much of a problem. the rear end wasn't touched, but the specs weren't bad, though I can't remember the numbers exactly. camber was around -2.0°. did I possibly bend or break something, or could caster make this happen? it's been a pain in the ass.
Sent from my DROID RAZR using Tapatalk
