Might need to change springs...
  • Bimmerfanatik
    • May 2004
    • 5349
    I have an 87 cabby.
    I'm on H&R race (coupe) springs - love the stiffness and handling, hate the drop height (cosmetically great, but these roads SUCK in NE, and I scrape everywhere - and yes, I know how to drive a lowered car.)
    I'm considering swapping them for H&R sports (coupe, 50406) but I don't want to lose handling or stiffness - just want the car to ride a bit higher.
    Here's what I'd like:
    H&R race spring rates, drops
    H&R sport (50406) spring rates, drops
    H&R sport (29664) spring rates, drops
    Cabbie specific H&R sports (50407) spring rates, drops
    Pics of any of the above setups - bonus if it's on a vert.
    I appreciate any help guys...
  • AndrewBird
    The Mad Scientist
    • 11898
    How much higher do you want the car to be? You could just double up on spring pads if you only want it a little higher.
    • Bimmerfanatik
      • May 2004
      • 5349
      I considered that - though the car is stupid low - H&R races are an agressive drop initially, then with the added weight of the cabrio things just go lower. How thick are the spring pads? ie how much higher could I raise the car with them? I think bringing the car up about a half inch or so (the front is probably at a 2" drop right now) would suffice...
      • Mystikal
        Wheel Fitment Expert
        • 9602
        Spring rates:
        H&R Sport : 182/343
        H&R Race : 315/570
        For a more streetable ride height and real stiffness, your only option is GC's. Just do it right the first time, you'll love the ability to fine tune the ride height and spring rates.
        • MrK
          • Jan 2006
          • 709
          Well, 10mm pads (available OEM) will raise the car about 1/3 to 1/2 inch if I'm not mistaken, and they don't cost much. Consider it.
          This is your M20 on steroids:
          • asubimmer
            • 6482
            i'll trade ya for some bav auto's ;)
            • Jand3rson
              • 37587
              I agree with Jay, but also with Andrew. If you don't have the cash or feel like swapping to GC's, throw some extra spring pads in there, it will bring you up some.
              • AdironRider
                • Dec 2004
                • 3491
                Ha, now you understand why I went through all the trouble to raise up my car? Id go with the spring pad idea at least initially, seeing as your car is only a summer car. If that doesnt work out Id get the cabrio specific sports, I love the handling and spring rates on my OE sports, and they should at least be similar to what the sports would be like on a cab.
                Back to my roots
                • Bimmerfanatik
                  • May 2004
                  • 5349
                  Spring rates:
                  H&R Sport : 182/343
                  H&R Race : 315/570
                  I can't justify completely overhauling an already well done suspension to gain a half inch of height. I LOVE this setup - it's just too low on the car. I think I'm going to grab new spring pads and see if it helps. Remember, I'm using coupe springs on a vert - the rear is heavier and I'm sure goes lower than a coupe's. Check my pics in the member's rides.
                  Don't get me wrong Jay - if this car was on stock suspension, I'd go GC's the first time and call it a day. But the bilsteins and H&R's were on the car (thanks again Dave ;)) and I'd rather spend my money elsewhere. It handles like a dream - it just scrapes like a bitch ;)
                  Seeing the MUCH higher spring rates on the races, I've got to see what I can do about the spring pads - I don't want to go to a softer spring.
                  Any p/n on the 10mm ones? Just want to make sure I buy the right ones...
                  riiiight....I rode in someone's car with bav springs. swore I'd never do it again ;)
                  :up:
                  Yeah, but your car was on the cup kit - which was STUPID low, and soft as hell. At least my car is stiff!
                  I'm gonna try the new spring pads - even a little rake would be nice :evil:
                  • AdironRider
                    • Dec 2004
                    • 3491
                    This is true, and I had the busted oil pan as a result. Im happy with the car higher now.
                    Back to my roots
                    • MrK
                      • Jan 2006
                      • 709
                      Rear 10mm pads: P/N 33531136387
                      Ain't none for the fronts, sorry. Then again I assume your major problem lies in the rear height anyways, so it's all good.
                      • Bimmerfanatik
                        • May 2004
                        • 5349
                        Much obliged - and yes, it's the spot where the cat-back meets the cat that really scrapes...bringing the rear end up a bit should help ;)
                        • Rob
                          • 8166
                          FWIW- I'm absolutely loving 450/550 GCs at ~.75 lower than stock ride height.
                          BEERTECH
                          • Bimmerfanatik
                            • May 2004
                            • 5349
                            You're also a few miles south of here, Rob - those spring rates are killer with the potholes we face up here. I'm not worried about the ride - I can handle that. I'm more concerned with physically damaging the car with an impact like that ;)
                            • Mystikal
                              • 9602
                              Yes!
                              When I had the car setup higher than stock with 300/440 GCs, it was amazing. Bottoming became a non-issue, I was throwing the car around like no other.
