Can you fit a dremel in there and just cut the whole nut and stud in half from the top? From then you should be able to pry it all apart and pull it out.
1992 Mauritiusblau Vert
2011 Alpinweiss 335is coupe
I would take the stock out, and the washer around the nut to give more space. dremeling the nut sounds like the best option. Do you wanna re-use the old strut mount?
exactly what I'll do this eve.
Originally posted by flyboyx
i have watched my dog lick himself off a few times
Dremel simply was too blunt to fit in access hole.
I went at it with an air chisel. A straight edge , and a claw foot.
Managed to break most of the bolt off. It's literally rust fused to the strut mount.
It can sort of spin it(about a quarter turn) and I can pry at it from underneath.
It just won't give.
I started using a chisel and a hammer to chip away at the bolt itself now, I've pried at it so much that the metal seems/feels to be weakening now *banghead*
I'm running out I ideas here. I could use a air cutting tool from the underside, but that creates intense amounts of sparks and I'm not comfortable with that being it so close to he gas tank and fuel filler.
Thoughts?
