Well, I'm sure everyone has seen the group buy for the full suspension kit. This will be my first venture into ordering a suspension with my preferences instead of just going with what the spring is (I'm a shock/spring guy). The car is my daily and will see a few autox's each year (2-3 max) for fun. From my limited research I found that 300f 475r is the typical spring rate that people get on a 6" spring. Now my question to you, it seems as though these rates are relatively low, maybe i'm used to hard suspensions but my old hatchback had similar rates and it weighed much less (basically raising the rate even more from what I've come to believe). So does anyone have some imput on some good aggressive daily spring rates for a 325i?
Thanks much in advance!
