Something lovely this morning
  • G-Man the Visionary
    • Apr 2013
    • 543
    Got me some "death wobble" on the way to work this morning... Suspecting these shotty used tires that just got put on to hold off til wheel decision is made. Hoping it's nothing more than bad rubber.
    Streetable poly mounts, trans mounts are here!
    http://www.r3vlimited.com/board/show...ght=streetable
    '94 318i
    '07 335i
    '11 X5
    '89 325ic m30b35
  • Reichart12
    • Aug 2012
    • 2168
    Hope the drive wasn't long for you. That's always freaky to have happen.
    Instagram: Reichart12
    • the imitator
      • May 2013
      • 1006
      Just one up the wobble, and swerve.
      Wobble should go away upon swerving.
        • Apr 2013
        • 543
        Thanks, it sure was a crazy experience. Luckily only 3 miles away from work when it happened, did pull over to make sure there was even a wheel. Couldn't go over 70 after that, which makes me also wonder if it needs new ball joint, cab, etc...
        Hahahaha seriously? It did happen when hitting a bump at about 100...
        '94 318i
        '07 335i
        '11 X5
        '89 325ic m30b35
          • Apr 2013
          • 543
          Front right tire was the suspect... Has a nice sized bulge, I'm guessing from the pothole at 100 thing... Can you return used tires? Lol
          '94 318i
          '07 335i
          '11 X5
          '89 325ic m30b35
          • E30DriftMissile
            • Aug 2012
            • 301
            hahaha creepy man, but depending on the shop if you didnt put too many miles on it they should be warrantied
