Have a few questions and wanted to run my list of parts by this esteemed forum. The car is an '87 325is 5spd coupe (that we are on the fence for keeping or selling) and if I do suspension, I'd like to do it all at once; bushings, upgraded parts, and modifications. The car is not a daily driver, it's a fun car and my wife and I both appreciate a sporty ride. We might track it some day, who knows.
Here is my list, am I missing any "while I'm in there" parts?
Turner Motorsport
E30 Suspension Package With H&R Race Springs and Bilstein Sport Shocks
Part #: E30RACE
Front Upper Strut/Shock Mount - Offset Left or Right Side - E30, E24, E28
Part #: 31331139484
Front Control Arm - Left - E30 OEM Replacement
Part #: 31121127725
Front Control Arm - Right - E30 OEM Replacement
Part #: 31121127726
Front Control Arm Bushings (FCAB) - Centered Solid Rubber - E30, E36, E36 M3, Z3 (Pair)
Part #: 31129069035
- Yes, AND pre-install bushings (pn# TSU9995PB3/035)
$185.95 (USD)
Rear Spring Pad - 5mm - E30 E36 E46 X3 Z3 Z4
Part #: 33531136385
Ireland Engineering
Adjustable 25mm Front / 22mm Rear Sway Bar Set for E30 | [e30sbs]
Tie Rod Assembly for E30 (FEBI) | [e30trod]
Billet/Urethane Rear Shock Mount Set for E30/E36 | [e30alummt]
Urethane Rear Trailing Arm Bushing Kit for E30/E21/Z3/E36ti/E9/E12/early E24 | [e30rearbush]
Urethane Rear Subframe Mounts, Street - E30 | [e30urethanerear]
Stainless Steel Rear Shock Tower Brace for E30 | [e30rbrace]
Front Strut Brace for E30 | [e30sb]
HD Rubber Transmission Mounts - E30, E36 | [e30transmtrbr]
Urethane Rear Differential Mount for E30 | [e30diffmt]
I'm unsure on the offset front strut mounts. Should I use those and/or fixed camber plates?
I'd like to replace all rubber items while I'm in there, like rubber spring pads. Should I add any other parts, aftermarket or OEM to do spring pads?
The Ireland Engineering sway bar kit, the reinforcements, are these metal plates ok vs the other setups that require welding in reinforcement tabs?
Turner Motorsport
Part #: E30RACE
Part #: 31331139484
Part #: 31121127725
Part #: 31121127726
Part #: 31129069035
$185.95 (USD)
Part #: 33531136385
Ireland Engineering
