H&R Sport with Billy Sport ride question
  • Poeman446
    • Jun 2013
    • 227
    First, I am a complete idiot with suspension, and my searches that turned up few results just prove that.
    So, I have put an S52 in my 87 325is, and then I installed Bilstein Sports with H&R sport springs from Turner on just the front (My rears are sitting waiting to be installed). Its notably lower, as I expected, but it seems too low. My exhaust is from an E36 M3. Long tube headers run to the E36 Midsection to an aftermarket E36 catback. It scrapes on my gravel, it scrapes on rough patches in the road, it hits on low spots in the road, etc. I'm used to driving a jeep grand cherokee, so I obviously am not used to riding lower yet, but Is this how its going to be for good? I have not installed the rears yet because I dont want to lower the rear any more and completely rip my exhaust out. It looks to be hung as tight as possible to the body. If this is how its going to be for good, I think im going to sell the shocks and springs and go back to stock or get some stiffer stock height springs.
    Next solution. Am I able to fit bigger wheels to fix my ride height problem? I know the speedo will be off, but I dont care about a couple of percent here or there.
    Sorry for being such a suspension idiot. Thanks for any insight, or any resources that will help. I just dont want to be buying oilpan after oilpan over this.
  • adonwilson
    • Mar 2012
    • 314
    I had this same setup and never had clearance issues. I went with a lower setup and now I need to be careful of the pan and exhaust (right behind the headers is really low). You sure you didn't get the race springs? What size wheels/tires do you have now?
    • Poeman446
      • Jun 2013
      • 227
      I'm pretty darn sure I have the sport springs. They match the sport part numbers, but I will check again. I'm running stock weaves with stock size tires. I think my exhaust hangs a bit lower than stock for the larger pipes, but its really not that much different from where it was. I think my main hitting problem is on exhaust, and its due to the connections between cats (Midsection) and the catback. I might try to remove some under guards and push it up a bit higher.
      • Boris3
        • Apr 2007
        • 444
        Did you put the rear springs on the front by mistake?
        1990 325: track/racecar
        2003 330xi; project car
        2004 330i zhp: civilized car
        • rmdashrf
          • Feb 2014
          • 207
          I dont see how that is possible, lol
