Are you guys running limiting straps in the rear or what is the plan to keep the spring from running away? I'm running rear shocks with a 20" extended length (KYB 98 Camaro) and I know the springs are not captured under full droop when jacking the rear of the car up with my adjusters in place. Am I being overly paranoid?
If I want to run no adjuster (or even now... really) then I've reasoned my options out to the following:
Limiting straps
Move to shocks that have a shorter extended length (16" - KYB 94 Mustang)
Rear shock mounts that are extended upward
Combination of the above?
Any other ideas or something I'm overlooking?
Limiting straps
