Front Suspension Overhaul Questions.
  • E30NJ
    • Aug 2013
    • 921
    Hello!
    Well, looks like that time of year. The PO had the sway bar bushings installed incorrectly and it snapped part of the subframe. I have found another uncracked subframe that I will install and also install all new front suspension components. I was also wondering if it might just be worth it to also drop the steering rack (because the boots are ripped) in order to do a oil pan gasket while I'm there. Any thoughts?
    Thanks.
    -Dan
    Since you will be removing the subframe, leave the rack attached to it and just disconnect the PS lines and steering shaft.
    • dude8383
      • Jan 2005
      • 10387
      Get the front subframe reinforcements from Garagistic:
      Garagistic is your trusted source for high-quality BMW performance parts, specializing in E30, E36, E46, and more. Discover custom-engineered components, from suspension upgrades to drivetrain solutions, designed to enhance your BMW's performance. Shop now for fast shipping, expert support, and unparalleled quality.
      If you don't have an E36 rack yet... now is a good time to do it ;) Otherwise control arms, E30 M3 lollipop bushings, sway bar end links and tierods.
      Small plug... but we can get all of that stuff for you as well.
