Memory steer
  • e30m3ochoa
    • Aug 2012
    • 136
    Memory steer
    So I had my car aligned after replacing the lower control arms, sway bar links and toe rods. I was told that I have memory steer and I'm wondering what might cause that to happen. Any suggestions will be helpful.
    Binding upper strut mounts can cause this.
    • e30m3ochoa
      • Aug 2012
      • 136
      So pretty much the bearing on the strut mount that's damaged or worn out?
        Yep.
        • e30m3ochoa
          • Aug 2012
          • 136
          Yep.
          Well what if it happened when I installed the lower control arm that I started noticing that?
          • AndrewBird
            The Mad Scientist
            • 11897
            Was the control arm new? If not, could be a seized up ball joint. Even if it is new, it could still be seized up.
            • e30m3ochoa
              • Aug 2012
              • 136
              Yeah it was new and that can be a possibility. It was super hard to move when I was installing the control arm.
