So I just got my first E30, a 1987 325is.
The steering is pretty sloppy so first I figure I'll change the tie rod ends (then I'll see if inner need changing, then will change the CAs and CABs). I got replacement tie rod ends, but when I went to get the old tie rod ends off, I'm running into the following problem:
I go to take the nut holding the tie rod end to the knuckle, but the bolt is rusty and the tie rod bad, so when I turn the nut it just turns along with the tie rod bolt. There's no room for any vice grips in there or an impact wrench, so I'm planning to just take a nut buster to it break the nut to get it off, but perhaps there's a simpler way?
