steering making noise....
  • SLEEPERracer
    • Oct 2004
    • 215
    my car recently has been making some noise everytime i turn wen im parking. wen im driving i dont here anything. but sometimes after ive been driving around for awhile i dont hear the sound anymore. i checked if there was fluid and there was plenty. everytime i steered all the way to each side while not moving the fluid would leak out from the top cap of the fluid resevior. i checked for leaks cause i believe there is air in the system cause everytime i would steer and it would make the noise i would see air bubbles come up form inside the resevior. i didnt find anywhere leaking. the sounds is like chubackas from star wars in my car.....anybody know whats up?
    also if it is the steerinig rack which i was also told would a 1986 318i steering rack fit?? thanks!
  • redhatpat
    • Aug 2005
    • 656
    Maybe the power steering belt is slipping under load?
    • SLEEPERracer
      • Oct 2004
      • 215
      well it is kinda new...couple months....should i just change the belt?
      cause it kinda did start happening when i removed the belt and put it back on. before that it never made that noise.
      • e304me
        • Feb 2006
        • 1374
        just tighten it?
        • SLEEPERracer
          • Oct 2004
          • 215
          Originally posted by e304me
          just tighten it?
          well i thought it was tight enough but i guess not... il try and see what happens...thanks!
          • DEV0 E30
            • Oct 2004
            • 8904
            Try flushing it, sometimes the power steering resivour collects dirt. And be sure you are using ATF fluid.
            • jackyl
              • Sep 2005
              • 76
              Hi.
              Mine does the same.
              When i start the car, i ear a zzzzzzzzzzzzz...zzzzzzzzzzzzz everytime i turn the steering.
              After i ride a few minutes the zzzzzzzzzz goes away.
              The sound is like you reach the end of the turning and keep pushing.
              • ummagawd
                • Jul 2006
                • 144
                has anyone figured this out yet? Mine does it too
                • RobertK
                  Kicked cancer's ASS.
                  • Jun 2005
                  • 5864
                  The only time I have ever noticed such things is if my PS fluid level is low.
