Tapping Die for 51mm Strut Housing?
  • funcrew
    • Jun 2007
    • 1223
    I have a 51mm (325i) right-side strut housing with bad threads. I can screw the KYB gland nut in about half way, then it sticks. Does not appear to be cross threaded. No obvious dents or damage to the female threads in the housing. Gland nut looks perfect. Do they make a tapping die to dress the threads on the strut? It's a 65K strut on a 65K car; I'd rather not replace it if it's repairable.
    Housing probably got damaged because gland nut loosened off gradually, and the strut banged around in the housing for a few weeks until I had a chance to pull it out and inspect where the noise was coming from.
    Thanks!
    "If the sky were to fall tomorrow, the tall would die first."
    -Dr. Paul Forrester
    Do I LOOK like I need a psychological evaluation???
  • haggardfab
    • Sep 2011
    • 283
    they sell files with teeth profiles cut into them, you MAY be able to find the correct metric pitch and try one of them by hand if the threads just have dirt/rust scale in them
    i dont know what thread the strut is off hand but something that big, and metric, will likely be EXTREMELY expensive, especially for one time use
    IG: haggardfab
    • RedReplicant
      • Oct 2009
      • 270
      Yes, but they are like $250.
      91 318is - Gone
      16 VW GTI
      07 Aprilia Tuono
      • funcrew
        • Jun 2007
        • 1223
        Thanks for the information. I will source a replacement strut.
        -Dr. Paul Forrester
        • LJ851
          • 7919
          Clean/straighten the threads with a thread file. They are cheap and a handy tool to have anyway.
          Lorin
          The M30 is God's engine.
          • Balleristic31
            • Aug 2009
            • 4198
            I bought one for about $95 to tap threads on the housings in order to be able to shorten them without sectioning. Worked great, but took a lot of time, effort, and patience to cut the threads nicely. I think I bought the tap on amazon.
            -NICK
            • raudonis
              • Jan 2013
              • 184
              I once had female thread (steel) that had bits of male thread (aluminum) stuck dead to it. They were oil pipes for m20 oil cooler. Cleaned up by hand using an awl with a sharply bent tip.
              My transaction feedback on r3vlimited :):Clickety click
              • 808e30325i
                • 537
                Just take it to a reputable machine shop and do it right.
                • FredK
                  • 14761
                  It's M48x1.5, if you want to get a tap.
                  • LJ851
                    • 7919
                    Originally posted by FredK
                    It's M48x1.5, if you want to get a die.
                    ftfy.
                    Lorin
                    • Mr. Tasty
                      • Jul 2011
                      • 3421
                      Originally posted by LJ851
                      ftfy.
                      it is a tap though. Unless referencing death.
                      2014 Alpine White 335i MSport
                      (Daily Driver)
                      Full Mperformance Aero
                      KW V2 Coilovers
                      VRSF Catless Downpipes
                      • LJ851
                        • 7919
                        Taps are for internal threads, Dies are for external threads.
                        It's a Die that OP wants.
                        Lorin
                        • Mr. Tasty
                          • Jul 2011
                          • 3421
                          Weird, my housings had internal threads.
                          (Daily Driver)
                          KW V2 Coilovers
                          • LJ851
                            • 7919
                            Haha! My mistake, i've been working on too many other cars recently.
                            Lorin
                            • Mr. Tasty
                              • Jul 2011
                              • 3421
                              :up:
                              (Daily Driver)
                              KW V2 Coilovers
