This suspension rebuild kit worth it?
  • -negrito-
    • 91
    Yesterday I was driving on the highway and slammed on the brakes because the car in front of my stopped no apparent reason. My ABS is not working so my wheels locked trying to stop my car. Thank goodness no accident.
    Right after that I can feel a vibration coming from the front passenger wheel. I was thinking probably my wheel adapter came loose. After examining this morning I found out its the tie rod that went bad.
    I might as well invest on rebuilding my suspension. Only thing "new" is are Bilstein Sport Shocks and ST Suspensions coils (less than 10k miles)
    I saw this rebuild kit from ECS wondering is it worth it? LINK
    Any other suggestion I would appreciate it.
    TIA
  • Cabriolet
    • 9620
    If the brand is good, it is worth it. it doesnt say the brand.
    I and most prefer the e30M3 control arm bushings. but that's not a huge deal.
    this is a good quality kit, i've installed it. But it does cost more.
    Much wow
    I hate 4 doors
    • -negrito-
      • 91
      This is the brand for each part of the kit.
      Washers - Genuine BMW - 4
      BOLT - Genuine BMW - 4
      M3 Front Control Arm Bushing Set - Lemforder - 1
      Rear Stabilizer End Link - Lemforder - 2
      Self-Locking Collar Nut - Genuine BMW - 4
      Tie Rod Assembly - URO - 2
      Front Stabilizer Link - URO - 2
      Subframe Mount Bushing - URO - 2
      Steel Front Control Arm - Left - URO - 1
      Steel Front Control Arm - Right - URO - 1
      Rear Reinforcement Plate - ECS - 2
      Upper Strut Mount - CRP - 2
      Shock Mount Gasket - Elring - 2
      Control Arm Bracket - Left - Vaico - 1
      Control Arm Bracket - Right - Vaico - 1
      Differential Mount Bushing - Vaico - 1
      Rear Shock Mount - Lemforder - 2
      Trailing Arm Bushings - Pair - Febi - 2
      • kronus
        • Apr 2008
        • 13032
        you probably flat spotted the shit out of your front tires, is the reason for vibration.
        emergency braking won't ruin a tie rod.
        check your tires first.
        cars beep boop
        • BruceJ
          • Sep 2012
          • 62
          I'm looking at doing the front end with the same components. Also putting in a e36 steering rack and springs/struts/shocks at the same time. I have used similar before on my e46 60k miles ago. It tightened up my handling very nicely.
          I would tell you to get the front end kit only. Piece the rear kit separately and skip the std rear bushings to add toe/camber adjustment. If you have to drop the rear subframe you may as well.
          Good luck
          Bruce
          89 e30 white vert
          88 e30 Red vert
          2003 330i sedan
          2011 E93 335is
          2007 Z4Si (gone)
          • -negrito-
            • 91
            tires are fine. i jacked up the car removed the tire and theres some play on the assembly (sorry if im not explaining myself correctly). i'll take a small vid tomorrow.
            Good luck
            Bruce
            what are the advantages of putting a e36 steering rack?
            • TimeMachinE30
              • Jun 2014
              • 3749
              Search for all the details. Cliff Notes: more precise and faster steering.
              ACS S3 Build / Dinan 5 E34
              • Cabriolet
                • 9620
                Vaico and URO are brands to avoid. everything i've gotten from them, hoses, switches, etc have been less than on par.
                Much wow
                I hate 4 doors
                • dude8383
                  • Jan 2005
                  • 10387
                  Would like to echo those thoughts.
                  Vaico is okay though. Those URO control arms will last a year or less.
                  • turbo55
                    • Jul 2014
                    • 223
                    +1 on avoiding URO
                    • Steve Corbett
                      • Jul 2012
                      • 449
                      I agree, URO are no worth the time it takes to throw in the trash!
                      Steve Corbett
                      1983 528E Scrapped
                      1983 528E Sold
                      1984 745I
                      1984 325E - Sold
                      1989 325I Bronzit-Sold
                      1989 325I Zinno
                      1988 635CSI
