So I had a bad steering linkage guibo, which made the steering VERY wobbly. I removed the rack and changed out the guibo to a solid one from akg/catuned. this FIXED the steering wobble.
My problem now is that sometimes if i turn the wheel from center i will get to a point right after turning the wheel where it breaks over. it almost tightens up a little and then snaps over and turns the rest of the way.
To me it sounds like the u joint on the linkage is binding and then snaps over. but im ruling out the linkage, because im not an idiot and was in perfect working condition when i swapped the guibo out.
I also want to note ive had problems with the steering ever since i bought the car, between the wheel wobble, and the steering lock not working. the previous owner broke it or something.
any other thoughts or wear points? Thanks in advance
