low speed popping while turning
  • bimmers4life
    • 420
    my car makes all sorts of popping sounds when i make low speed turns. So what exactly is making this sound?
  • rwh11385
    lance_entities
    • 18403
    GROUND CONTROL!!!!
    OMG IT MAKES POPPING SOUNDS, TIME TO BOYCOTT THEM...
    camber plates?
    my guess is your springs are binding and you need wheel bearing grease, to clean your strut mounts or whatever, and use some zip ties. it's on bimmerforums.
    • Erick
      Official R3V Drifter
      • 11169
      Control arm bushings?
      ..::Support FullOpp::..
      FullOpp Stickers for sale!
      Feedback Thread
      • bimmers4life
        • 420
        I think it might be the coils binding because i have never heard of m3 control arm bushings making the popping sound, only the treehouse ones. It just gets real annoying when every ten minutes i get someone asking "whats the popping noise?"
        Here is a list of my suspension upgrades as of right now...
        Suspension
        Front:
        -Ground control adjustable coil overs
        -Ground control adjustable camber and caster plates
        -BMP Front Strut Brace
        -Bilstein Sport shocks
        -Suspension Techniques 22mm Anti Sway bar
        -M3 Contol Arm Bushings
        Rear:
        -Ground control adjustable Coil Overs
        -Bilstein Sport Shocks
        -Suspension Techniques 19mm Anti sway bar
        -Heavy duty shock tower mounts
        • rs4pro3
          • 5808
          sounds like the camber plates, My Ireland plates pop also.
          85 325e 2.7 ITB'd stroker
          • rwh11385
            lance_entities
            • 18403
            mine do it.
            OH NOES>!>!>>! OUR RACE PARTS MAKE POPPING NOISES!>!>?!?!??!??
            MY STREET CAR IS NOISY>..>> ARGHAGHHG
            • bimmers4life
              • 420
              Originally posted by rwh11385
              mine do it.
              haha, your a fuckin jerk! It aint that big of a deal, i was just hoping there might be an easy fix for it. oh well :)
              • rwh11385
                lance_entities
                • 18403
                it wasn't in reference to you dude, it was making fun of people who are complaining about THR eyeballs, etc.
                But you can clean your shit real well and grease it, it should help. I've been meaning to do it too, as I have the same problem.
                • yozsi
                  • Feb 2006
                  • 337
                  ground control makes those roller needle bearings for the camber plates. i have them on my ITS 240z and my car doesnt pop.
                  Unlimited Slip Diff's FTW!
                  1972 240z Drift,Scca BSP, Scca ITS Car.
                  • bimmers4life
                    • 420
                    sounds good ill have to look into that
                    • dirty30
                      • 3098
                      I am using the GC camber plates currently and must say the top spring hats with the needle bearings took care of alot of binding and some noise associated with linear rate coilover springs. Keep in mind the GC camber plates eliminate any rubber between the strut and the body of the car making for even more unpleasant noise. Increased harshness over bumps and road imperfections is common...fuh raze parts= fuh raze noise. I wish I could send you some in car audio from mine...sweet jesus....
                      • rs4pro3
                        • 5808
                        The ireland plates use roller bearings between the spring seat and the plate but they still pop, if you have 2.5" springs you can pick a set of these up
                        that go between the spring and the spring seat
                        • Rob
                          • 8166
                          coilovers make noise. You can minimize it, but its still not a factory setup with rubber isolaters all over the place...
                          BEERTECH
                          • static
                            • Oct 2005
                            • 501
                            hmm, i have MF plates, perches and H&R sport springs, and i hear all kinds of pops after i installed these susp components
                            what gives?
                            • HellzMindPlaya
                              • 395
                              This is why I need to learn to search better... I just overtightened the nut that holds the top of a brand new strut into my new Ground Control Camper/Caster plates and stripped it out... Hopefully it isn't to dangerous to just rethread it. A new strut costs like $230.
                              e30 Sold long ago - Too many BMWs since then... For now 2006 M5
