Hoping for some input, with the weather getting a bit nicer and the budget getting a bit smaller I'm getting into tackling some projects I've been putting off for a while.
1990 325i sedan, S52B32 w/m50 manifold
G260 trans
3.73diff running thicker clutch discs
22mm front/19mm rear at full soft
H&R Sports
Koni SA all around
I'm debating ditching the 19mm rear bar and going to either a stock e30 sway, or the 14.5mm iX. What would you guys recommened? I love the setup on the street (aside from the occassional creaking/groaning from the trunk floor) but it is tough to handle on track. I find I have plenty of traction for straight acceleration but it wags the tail if I even so much as look at the throttle the wrong way in any degree of a turn. Quite often I need to almost completely straighten up to start going beyond neutral throttle at corner exit. My instructor was an e30 guy and strongly advised me to tone down the rear bar, does r3v agree with his recommendation?
I have an iX bar and bushings on hand, but no stock 12mm setup. Alternatively I hear that removing the rear sway outright can often work well in higher horsepower apps.
G260 trans
H&R Sports
Koni SA all around
