Ride hight, passangers side to drivers side 30mm
  • buffalino
    • Jun 2010
    • 61
    Just changed shocks and springs, and there is a difference of 30mm why would this happen , It was the same before i changed the bits, where is this problem coming from?
  • AndrewBird
    The Mad Scientist
    • 11898
    I'd let the springs settle for a week or so then re-measure.
    Did you change the strut mounts as well? They could be worn different amounts.
    • buffalino
      • Jun 2010
      • 61
      Its been a week now, also changed the strut mounts, also removed the lump of lead under the battery in the trunk(25kg) the problem is on the rear of the car!
      • buffalino
        • Jun 2010
        • 61
        Anyone with any more ideas? this is not good
        • george graves
          • 20003
          Bent frame?
          Apparently it's not the springs. 30mm is over an inch. That's way wrong. Even the worst more corse springs on a pick up truck won't be off by an inch.
          If you kneel don by your car, and sight down it's fenders, does it look twisted?
          Originally posted by Matt-B
          • buffalino
            • Jun 2010
            • 61
            No nothing looks twisted,! and i did a few measurements, all seems good,i can only put it down to a fucked shock,
            • ELVA164
              • 4861
              What type of dampers did you install? I suppose if they were adjustable and one was super soft while the other was super stiff, that could affect it...is everything sitting right? The springs are seated properly?
