steering rattle when traveling >50mph
  • BeaterE30
    • Oct 2013
    • 35
    I recently got into an accident that fucked up the front right fender of my car. I basically slid into a guard rail that caused the fender to push against the wheel. I was able to cut away the fender so the wheel has enough clearance. Since then, I have noticed that when I travel on the freeway at speeds over 50mph, a slight steering rattle occurs. Its nothing TOO severe, but it started happening after the accident. Braking doesn't seem to make the situation any worse.
    Ive done some research and people say that it could be:
    warped rotor
    tire out of balance
    tie rods
    broken control arm bushings
    Any ideas?
    1985 528e
    1991 325ix
    1992 318i Convertible
    "this question is kind of like asking: would you rather be ass raped by a gorrilla with lube on his dick or butt pounded by a prison inmate with size 14 shoes and no lube....?"
  • LJ851
    • 7919
    My crystal ball says bent wheel and/or out of balance tire.
    Lorin
    The M30 is God's engine.
    • ELVA164
      • 4861
      ^Yup. Or maybe a ball joint/tie rod end on that side is loose now.
