Replacing My Rack
  • sticksdaman
    • Apr 2005
    • 2987
    Replacing My Rack
    Tommorow i will be replacing my steering rack is there anything that i should look out for? Also in the manual it says that i should replace the bolts on the U-joints as well as the washers by the part on the rack where it meets the power steering lines... My question is can i get a way with re-using the old ones?they appear to be in good condition i inspected them but i wante dto consult you guys prior to going against the manual. i really would rather not go to the dealer to get new ones because the dealer is some 20+ minutes away and i would hate to go there and them not have the parts.
    Originally posted by ebelements
    Also, for those who don't know, negative camber is the greatest thing since sliced bread(panera). Even tire wear is for city busses and the elderly.
  • 500ke30
    • Oct 2004
    • 133
    it's pretty straight forward, you can re-use all of the bolts.
    Count down to 1,000,000 miles: 490,649 to go
    • Brew
      • 3060
      Replace the crush washers on the power steering lines you take off/loosen.
      This would also be a good time to check for any play in the ball joints and control arm bushings.
      '91 318is
      • sticksdaman
        • Apr 2005
        • 2987
        i checked the ball joints/ bishings they are in rater good cond.
        thanks for the help guys i was worried that it wouldnt be safe.....i figure dthe bentley put that in there so that pople could work on their cars without voiding the warranty
        • sticksdaman
          • Apr 2005
          • 2987
          where can i get those crush washers? can i get them locally? the local autozone doesnt carry them
