I've heard something about E36 Tie Rods on an E30. What are the benefits? Bolt-on fit? I'll be using a Z3 rack
E36 Tie Rods
2nd that.... Can you use both the e36 OR e30 tie rods for the e36 steering swap application?Recent Rebranding!!
E30 SM62/S62
E30 M60 V8
E30 M30 Big 6!
Instagram.com/garageaholic
Youtube.com/garageaholic -
Yes, you can use e36 tie rods in an e30. I used the ones that came with my steering rack. They bolt in and operate like normal.
According to Zionsville, the e36 tie rods are shaped a little differently so that your tires are less likey to rub on the tie rod when you have really wide tires.
-ErikComment
Is the wheelbase the same where you don't have to extend/retract the tie rods from the e36 to the e30? or is the wheelbase exactly the same where you don't need to do that...Recent Rebranding!!
E30 SM62/S62
E30 M60 V8
E30 M30 Big 6!
Youtube.com/garageaholicComment
