Hello R3v gods and OG's I need a little assistance. Let me first off say if this information is posted somewhere please provide me a link I couldn't find it through the search function.
I recently got my rebuilt bilstiens back (IX front, Sport rears) and will be cutting and modifying the strut housings for a 6" ground control kit. However I cannot find anywhere an exact spec of how much of the strut housing needs to be removed for the shorter IX shocks. I have heard anywhere from 1" to 2.25" with no definitive answer. From what I have seen the IX struts are around 3" shorter than the standard stock length so I assume some of the housing will be removed and a spacer put inside to make up the difference.
If anyone knows these specs off hand It would be a great help as I am itching to get these modified and on my car ASAP.
info:
IX front, sport rear shocks
GC front and rear kit 6" springs
GC camber plates up front
Will be run with 17" wheels in order to clear my brake set up (if that helps with spring to wheel clearance)
Thanks in advance!
P.S. dimensions for where to weld the threaded adjuster perch as well as M3 sway bar tabs would also be very useful!
info:
Thanks in advance!
